Configuring VSF on 2930F with VSF-MAD
I have two 2930F switches and would like to configure VSF VSF-MAD on  two SFP+ ports for load balancing and failure. Can You please axplain step by step procedure?
MVP Expert
Re: Configuring VSF on 2930F with VSF-MAD
Greetings!
I would recommend following the VSF deployment guidelines provided in the best practices guide attached to this post
Matt Fern
Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
