Highlighted
Configuring controller IP (on the controller)
Hi, I have a controller where I would like to change self IP or controller IP for tunneled node service. Currently it shows like this:
#show tunneled-node-mgr stat
IP address
self_ip: 10.133.5.61.
controller ipv4: 10.133.5.61.
I'd like to change this to another IP address/VLAN. If I try to connect switches to the other IP they fail with
TNT mtnodeUserCtrl:Switch Bootstrap Failed, Req sent to non controller or non cluster IP : 10.133.9.61
APs connect to 10.133.9.61 fine, but I can't create dynamic segmentation stuff.
