Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Occasional Contributor I
Connect Cisco 3560 to Aruba 2530 via SFP transceivers
Connect "Cisco 3560 series PoE-48" to "Aruba 2530 PoE-48" via SFP transceivers. We get no activity lights on the Aruba 2530 switch.
CiscoCiscoHPe ArubaHPe Arubathumbnail_20190620_161206.jpgthumbnail_20190620_160949.jpg
Highlighted
Contributor II
Re: Connect Cisco 3560 to Aruba 2530 via SFP transceivers
mismatch gbic. The cisco is a single mode and the aruba 1 is a multi-mode. Also what ever you choose make sure to use the correct fiber cable
Highlighted
Ok,
Is this what I would need then? And does "SMF" mean single mode, and "MMF" multi mode?
Aruba 1G SFP LC LX 10km SMF Transceiver
Link to SFP
Highlighted
MVP Guru Elite
Yes,
but the fiber cable i think it is for MMF (from color of cable)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Well, the cisco switches with those cisco tranceivers are currently operating on the network with that orange fiber.... They have been for years. We are replacing the cisco switches with the aruba switches throughout the entire network.
Highlighted
MVP Guru
The fiber optic cable shown, give its labelling, is for sure a 62.5/125 um Multi-Mode Fiber (MMF) OM1 cable.
Given that Cisco's SFP Transceivers are LH-SM (Long Haul Single Mode, I presume) then, using a MM fiber optic cabling (as it worked), it is possible (with degradation)...I suspect the contrary (SX MM Short Range Multi Mode SFP Transceiver on SM fiber optic cabling) it's a matter of being very lucky.
For sure there is a SFP Transceivers mismatch going on here (Aruba J4858D versus Cisco LH-SM)...probably a Cisco GLC-SX-MMD would solve the mismatch with the J4858D.
