Highlighted
Contributor I
Connecting HPE 5945 and aruba 5406zl Switch does not work
Hello Community,
I have a problem connecting a HPE 5945 48SFP28 8QSFP28 Switch (7.10.R6555) with an HP (aruba) 5406 zl Switch (K.15.18.0019).
In the comware Switch I have an JD118B LX Transceiver, in the aruba switch there is an J4859C Transceiver.
I configured the port the following way:
interface Bridge-Aggregation137
port link-type trunk
port trunk permit vlan 1 500
link-aggregation mode dynamic
stp root-protection
interface Twenty-FiveGigE1/0/37
port link-mode bridge
speed 1000
port link-aggregation group 137
interface Twenty-FiveGigE2/0/37
speed 1000
After connecting the switches the Comware-Switch, it says the link is "up", but when I look to the interface statistics I can see, that there are only outgoing packets, no incomming packets. The aruba switch says the link is "down".
Before I implemented the 5945 there was a HP 5920 in use. The same transceiver was working in the 5920, the config was the same, except the "speed" settings:
interface Bridge-Aggregation11
 stp root-protection
interface Ten-GigabitEthernet1/0/6
 qos trust dscp
 port link-aggregation group 11
interface Ten-GigabitEthernet2/0/6
 qos trust dscp
The Config in the aruba switch does not changed.
I tried the following:
in the aruba switch:
speed-duplex 1000-full
in the comware switch:
duplex full
but no changes.
Any ideas?
Regards.
Accepted Solutions
Highlighted
Re: Connecting HPE 5945 and aruba 5406zl Switch does not work
Hi guys,
I had the same issue. Turn out that I had to specify the speed and duplex on both ends.
As per the installation guide these ports does not support autonegociation.
Test it and give us feedback.
Regards
View solution in original post
All Replies
Highlighted
MVP Guru
Are you using a J4859C (LX Long Reach) on HP 5400zl side? Shouldn't be a J4858C (SR Short Reach)?
The J4859C works at a very different Central Wavelength (1310 nm) with respect to J4858C (850 nm)...and that is also valid for to the counterpart JD118B (850 nm)! it's cristal clear that pairing links served by a J4859C with those ones served by a JD118B will no work.
Try the J4858C...and report back.
Highlighted
Contributor I
sorry, it was a typo... the transceiver is an JD119B LX Transceiver.
Twenty-FiveGigE1/0/37 transceiver information:
 Transceiver Type : 1000_BASE_LX_SFP
 Connector Type : LC
 Wavelength(nm) : 1310
 Transfer Distance(km) : 10(SMF)
 Digital Diagnostic Monitoring : YES
 Vendor Name : HPE
 Ordering Name : JD119B
The same transceiver is working in a 5920AF switch
Highlighted
MVP Guru
Can you post sanitized outputs of show lacp, show trunks and show tech transceivers commands executed against the HP 5406zl?
Highlighted
Contributor I
of course
5406# show tech transceivers
transceivers
Transceiver Technical Information:
 Port # | Type      | Prod #     | Serial #         | Part #
 A24    | 1000LX    |     J4859B | P961PV6          |
 B24    | 1000LX    |     J4859B | P962APD          |
5406r# show lacp
                                    LACP
           LACP      Trunk     Port                LACP      Admin   Oper
   Port    Enabled   Group     Status    Partner   Status    Key     Key
   A24     Active    Trk1      Down      No        Success   0       290
   B24     Active    Trk1      Down      No        Success   0       290
5406# show trunks
 Load Balancing Method:  L3-based (default)
  Port | Name                             Type       | Group  Type
  A24  | Uplink                           1000LX     | Trk1   LACP
  B24  | Uplink                           1000LX     | Trk1   LACP
Highlighted
MVP Guru
What's about Trk1 member interfaces?
Could you also post the output of those commands (HP 5406 zl):
  • show interfaces brief ethernet A24
  • show interfaces brief ethernet B24
  • show interfaces transceiver ethernet A24 detail
  • show interfaces transceiver ethernet B24 detail
  • show running-config interface ethernet trk1
  • show running-config interface ethernet A24
  • show running-config interface ethernet B24
Down means that the physical port is enabled, but a LACP link is not established: this can indicate, as example, a physical port that is not connected to the network or a speed mismatch between a pair of linked ports.
Highlighted
Regular Contributor II
Hi Something or similar is not working using a Avaya 5520 Switch on the end or a Cisco 2960. We connect the links to that switches from an HPE 5945, link is up , but traffic not working.. Seems HPE SFP gbics problems. Currently testing several combinations shows that if you use Avaya Gbic on HPE 5945 side and HPE Gbic on Avaya side it works.. Wowww!!!!
Highlighted
Contributor I
Hello parnassus,
thanks for your reply,
actualy I am not on site so I can't give you these information. But do you think that there is something wrong with the 5406?
Because when I plug out the GBICs from the new 5945 and plug it into the old 5920 and connect it to the 5406, than everything is fine and up. The trunk/link-agg is working and traffic is passing in both ways. I don't have to change anything in the 5406.
It seems that either the configuration on the 5945 is wrong or the transceivers are not compatible together... :-/
Highlighted
MVP Guru
Hi! sorry I don't follow you...do you mean that the very same SFP Transceivers pair (JD119B) which IS NOT WORKING on the HPE 5945 once pulled out from 5945 and inserted on the HPE 5920 immediately starts WORKING without any other change considering that, in both cases, the LAG peer - the HP 5406 zl - is not touched at all (neither physically nor logically)?
Physical links running fromthe HP 5406 zl are the very same on both tests? I mean...Fiber Optic patch cords to HPE 5945 and to HPE 5920 too?
If so there is for sure an issue with configuration (or software version) on HPE 5945 side...have you done a like-for-like configurations comparison between 5945 and 5920?
Highlighted
Hi We have similar issues connecting fiber links with SFP's HPE ( JD118B ) against Avaya and Cisco Switches with their proprietary SFP. I can put a link working like this : HPE 5945 takes an Avaya SFP and Avaya gets an HPE SFP. as soon as we do this workaround traffic on both ways. We are pointing out to firmware problem...7.1 R6555 like the one on this post Regards Bruno
