Contributor I
Re: Connecting HPE 5945 and aruba 5406zl Switch does not work
yes, the GBICs are exactly the same. In the 5920 the link is working, in the 5945 not. I also used the the cabling.
I wrote the configuration of both switches in my first post. I cant see anything that could be the reason why this is not working, because there are no special settings... just a tagged VLAN
MVP Expert
Have you tried to use JD119B on back SFP Ports instead of using front SFP28 ports?
Contributor I
No, not yet. It will take some time to test it because I am not on site.
Hi guys,
I had the same issue. Turn out that I had to specify the speed and duplex on both ends.
As per the installation guide these ports does not support autonegociation.
Test it and give us feedback.
Regards
Regular Contributor II
Hi
Never seen this before
but a fact is a fact!
HPE5945 installation guide, page 70
NOTE:
• To connect an SFP28 port on the HPE 5945 48SFP28 8QSFP28 switch to a peer interface that does not support speed and duplex autonegotiation, you must execute the speed and duplex full commands on both interfaces. Configure the same speed and duplex mode for the two interfaces and the speed must be the same as that of the transceiver module or cable installed in the interface.
• An SFP28 port on the LSWM124TG2H does not support rate and duplex autonegotiation. You must use the speed and duplex commands to ensure that the interfaces at both ends of a link operate at the same speed and duplex mode. An interface can go up only when the speed configured for the interface is the same as the speed of the transceiver module or cable installed in the interface.
Regards
Contributor I
As I wrote in my first post, I tried the following:
in the aruba switch:
speed-duplex 1000-full
in the comware switch:
duplex full
but no changes. speed 1000 is already set.
Hi
Today we tested another link.
HPE 5945 side auto neg, Cisco side no negotiation. Guess what.
Link is up!
