Could we use Transceiver J9150A on Aruba 2540 Switch or Aruba 2930F Switch
Hi
We planning to upgrade non-poe switches to new POE+ switches Mostly 2540 48G POE+ 4SFP+ (JL357A) or Aruba 2930F POE+. Would we be able to use old transceivers J9150A on this switch.  Has anyone Tried it.
Re: Could we use Transceiver J9150A on Aruba 2540 Switch or Aruba 2930F Switch
take a look at the following.
https://support.hpe.com/hpsc/doc/public/display?docId=a00028947en_us
ACCX#1050 ACMP CWDP CWSP
