DSCP QoS Markings
Hi all,
I have a fleet of 5400 series switches ... I was looking at honouring DSCP markings for QoS reasons at these switches out to our WAN.
How can I honour DSCP markings and ensure certain ones take precedence over the rest of the traffic?
I will have a simple QoS policy as our WAN only honours 3 different DSCP values
MVP Expert
Re: DSCP QoS Markings
use qos trusted dscp on interface ?!
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
Thanks - worked nicely
(ArubaS3500) (config) #interface gigabitethernet 0/0/21
(ArubaS3500) (gigabitethernet "0/0/21") #qos trust <auto | dot1p | dscp | none>
