Disable build-in "manager" and "operator" accounts in Aruba 2530
How disabled build-in "manager" and "operator" accounts in Aruba 2530 ?
THX
MVP Expert
Re: Disable build-in "manager" and "operator" accounts in Aruba 2530
You can't remove the Manager and Operator access levels, what you can do is (a) associate to them usernames and/or (b) assign to them relevant passwords.
MVP Guru
Please check the ArubaOS-Switch Hardening Guide for this topic and other related security hardening topics.
