Does Aruba 8325 support MPLS (Multi-protocol label switching)?
Hey, I'm looking for switch with MPLS, does the 8325 support? or have any other Aruba solution? Thank you!
Re: Does Aruba 8325 support MPLS (Multi-protocol label switching)?
VXLAN and the Aruba Dynamic Segmentation solution can solve many similar MPLS traditionnal use cases.
This is not currently supported in AOS-CX but this would be interesting to share your specific MPLS use case.
Hey, thank you for your answer,
I just keep reading and find some information about HPE FlexFabric 5945 Switch Series that support MPLS, what you think about that?
Thank you
