Downloadable User Role Fails
MVP Expert
MVP Expert
Problem:
Downloadable user role fails.
Enable the following debugs:
  switch# debug security port-access
  switch# debug security radius-server
  switch# debug destination session
In the debug logs you see:
  0014:05:33:26.66 1X   m8021xCtrlSmiley Tongueort 1/2: sent Failure #21 to 005056-83f64d.
  0014:05:33:26.74 1X   m8021xCtrlSmiley Tongueort 1/2: fail to start session for client 005056-83f64d due to over-limit or internal error.
  0014:05:33:26.88 RAD  tRadiusR:Removing RADIUS REQUEST id: 167 from queue.
Diagnostics:
Commands Used
-- debug security port-access
-- debug security radius-server
-- debug destination session
Solution
This was resolved by correcting the switch configuration
Originally the switch had:  aaa authorization user-role enable
This was replaced with:   aaa authorization user-role enable download
Version history
Revision #:
1 of 1
Last update:
‎02-26-2019 07:11 AM
Updated by:
