Hi blu3nood,
From my point of view, if you miss configuring dynamic arp protection on one of your switches you will have one switch without this security feature enabled. Ther shouldn't be an issue with the network, as dynamic arp protection is running on every switch locally.
If someone is trying to insert a wrong arp entry it will work in this specific switch, but not for the others.
So no issue for your network to work, but it could be a security issue.
BR
florian
