Hi, I have a few Aruba JL320A 2930M switches which currently run POE Telephones.
I'm now looking to add some UniFi APs and would like to use the device-identity, device-profile and device-profile device-type commands to automatically set the correct vlans for the ports.
Does anyone know what the correct oui would be for UniFi APs and if I can set several tagged vlans under the device profile command?
Any guidance would be appreciated.
#2930M#2930M
