Dynamic Segmentation - Virtual Network Based Tunneling (VNBT)
To better handle business critical mobility and emerging IoT connectivity requirements, Aruba’s innovative Dynamic Segmentation solution simplifies IT operations and improves security by dynamically applying unified policies and enforcing advanced services anywhere in the network. This ensures that appropriate access and security policies are seamlessly distributed, automatically applied, and independently enforced for all wireless and wired users and devices.
This document provides guidance on architecting a Dynamic Segmentation: Virtual Network Based Tunneling solution in the Campus based on AOS-CX 10.5 with a focus on understanding the architecture and traffic flows. Sample configurations are also included to provide deployment guidance.
Version history
Revision #:
5 of 5
Last update:
2 weeks ago
Updated by:
Labels (1)
Contributors
Tags (2)
