ERR_SSL_PROTOCOL_ERROR after generating SSL certificate on 2930F.
I generated a self-signed certificate with the following command:
crypt pki enroll-self-signed certificate-name <SWITCH NAME> key-type rsa key-size 2048 subject common-name <SWITCH NAME> country US locality <CITY> org <COMAPNY> org-unit "Information Services" state <STATE> usage web valid-start 05/20/2019 valid-end 05/20/2029.
Problem is when I try to open the GUI from Chrome I get ERR_SSL_PROTOCOL_ERROR.
I can open the site fine (with warnings off course) with Edge/IE.
Not sure why I'm getting this error.
MVP Guru
Re: ERR_SSL_PROTOCOL_ERROR after generating SSL certificate on 2930F.
I just tried the same on a 2930F and it works for me in Chrome, though as I had a session before I created a new cert, had to open an Incognito window to initiate a fully new SSL session. Chrome does some session caching. Have you tried with Chrome from a different computer? I found a page that has some suggestions on Chrome to solve the issue.
Still no luck.  I've tried on 3 different machines and all the same error in Chrome.  I try it in any other browser it works fine.
Using Version 74.0.3729.157 (Official Build) (64-bit).
This is the exact error in Chrome:
This site can’t provide a secure connection 192.168.1.18 sent an invalid response.
Try running Windows Network Diagnostics.
I just removed the self-signed cert I created and re-created it and same error.  Just to make sure I disabled all extensions in Chrome and same result.  I've used this same command before and it's always worked.
MVP Expert
What firmware ? because there is some buggy firmware (first release 16.07, 16.08) you need to use last firmware and regenerate certificate...
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
Sorry for the delay.  Currently running WC.16.08.0003.
I do have some switches not in production that aren't on this firmware.  Might try it on them to see if I have the same issue.
You can follow this guide to fix this issue.
MVP Expert
There is a bug on some firmware release...
