Enterprise router options
Hi I was hoping for some advise on some options for enterprise router. I have a very good understanding on the Cisco ISR and ASR ranges and Juniper SRX lines and using those as routers. Could anyone share some experience with any other brands please?
I was going to look at some switches to see if that is a viable option that could be used in place of a routers and compromises would be made doing so I.e IPSec VPN not an option. Looking to achieve around 1Gbps throughput at 1500B packets. Has anyone ventured down this path?
I'm also not really aware of any white box routers are there any and are there any popular distributions. Or has anyone gone down using whitebox switches as an option?
MVP Expert
Re: Enterprise router options
If I was starting from scratch, I'd take a serious look at Aruba's SD-branch solution. The controller as router and security horizon make a fair amount of sense and the SDN architecture they propose look very good.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
