Error: Failed To Enable STP In Part Of Vlans Due To Not Enough Hardware Resource
MVP
MVP
Problem:
Switches configured with spanning tree mode PVST
Environment 1:
  • HPE 7510 Switch Chassis
  • Comware v5
  • Firmware before F6709L22
Environment 2:
  • Comware v7
  • Firmware any
Diagnostics:
When configuring VLANS on the switch, following error is received:
>> Failed to enable stp in part of VLANS due to not enough hardware resource.
Environment 1:
Switch currently has 128 VLANS configured and when configuring more than 128 VLANS the error is seen
Environment 2:
Switch currently has 510 VLANS configured and when configuring more than 510 VLANS the error is seen
Solution
Environment 1:
>> Maximum number of PVST vlans below version F6709L22 is 128.  From this version onwards it is 180 vlans
Environemtn 2:
>> Maximum PVST vlans supported on the switch running any comaptible firmware is 510 vlans
This is a chipset limitation and is working as designed.
Note: More VLANS can be configured on the switch however PVST will not be enabled on those VLANS.
Version history
Revision #:
1 of 1
Last update:
‎09-29-2019 12:08 PM
Updated by:
