Failed to log in to ProCurve 2510G if SFTP via IMC is used to back up the configuration
MVP Expert
MVP Expert
Problem:
Switch Crash:
TLB Miss:  Virtual Addr=0x00000014 IP=0x8053549c Task='tSsh1'
  Task ID=0x82bed7e0 fp:0x00000000 sp:0x82bed598 ra:0x8053fbcc sr:0x1000fc01
Diagnostics:
Detail
The switch crash appears when older versions of IMC are connecting for management purposes (in this case daily config backup) via SFTP
Solution
Resolved
The described issue is resolved by updating code to IMC PLAT 7.3 (E0506P07)
Version history
Revision #:
1 of 1
Last update:
‎10-03-2018 08:14 AM
Updated by:
