Filter the networks/prefix information to advertise to the neighbor using route-maps in Aruba OS CX
MVP
MVP
Aruba OS CX switch
How to filter the networks/prefix to advertise to the neighbor using route-maps
My topology:
R1(AOS-CX switch)----------------------R2(any other router or switch)  in the same OSPF Area 0
R1 has below config for VLAN and OSPF and route maps:
interface vlan200
    ip address 22.22.22.22/24
interface vlan201
    ip address 20.20.20.20/24
interface vlan202
    ip address 30.30.30.30/24
interface vlan203
    ip address 40.40.40.40/24
router ospf 1
    redistribute connected route-map vlan
    area 0.0.0.0
route-map vlan permit seq 10
     match interface vlan203
route-map vlan permit seq 20
     match interface vlan200
route-map vlan permit seq 30
     match interface vlan202
R1(config)# show ip ospf neighbors
OSPF Process ID 1 VRF default
Total Number of Neighbors: 1
Neighbor ID      Priority  State             Nbr Address       Interface
12.12.12.2       1         FULL/DR           12.12.12.2         1/1/1
With neighbor ID which is same, we could validate they are in the same OSPF Area R1 and R2
On R2 able to see only the routes which user mapped in the route map:
R2(config)# show ip ospf neighbors
10.10.10.10      1         FULL/BDR          12.12.12.1         1/1/1
R2(config)# show ip route
Displaying ipv4 routes selected for forwarding
'[x/y]' denotes [distance/metric]
12.12.12.0/24, vrf default
       via  1/1/1,  [0/0],  connected
12.12.12.2/32, vrf default
       via  1/1/1,  [0/0],  local
22.22.22.0/24, vrf default
       via  12.12.12.1,  [110/25],  ospf
30.30.30.0/24, vrf default
40.40.40.0/24, vrf default
So, we can see only routes which are matched in the route map are advertised by the R1 to R2 and with default metric 25.
Version history
Revision #:
1 of 1
Last update:
‎05-04-2020 12:10 AM
Updated by:
