Contributor I
Fimware Upgrade for Aruba 2930F Switch
Dear Team,
Kindly help me to update firmware for Aruba 2930F (Part Number: JL254A, JL260A) switches.
01. from where we can download the firmware image file.
02. Step by Step procedure for firmware up-gradation.
Regards
ASAMED.
Super Contributor II
Re: Fimware Upgrade for Aruba 2930F Switch
To download the software updates:
https://asp.arubanetworks.com/downloads
For upgrade information see the following:
http://h22208.www2.hpe.com/eginfolib/Aruba/16.09/5200-5913/index.html#c_Software_Management.html
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
