Where did you download those packages?
I just checked on both HPE MyNetworking Portal and Aruba Support Portal, and the files that I get do contain the correct build number.
These are the MD5 checksums that I get for the different versions:
MD5 (K_16_02_0026.swi) = 22fa6d2f17cb8c723b84a75e6e8a0413
MD5 (K_16_02_0027.swi) = adc2abeadb0aabbca8c9dc86e90cbf51
MD5 (K_16_02_0028.swi) = e8980217a91c4c70d399c3c50c9539c5
And sizes:
15740951 bytes K_16_02_0026.swi
15742071 bytes K_16_02_0027.swi
15742039 bytes K_16_02_0028.swi
Do you have the same?
If you do a 'show version' after you installed and booted the new firmware, what is the build-date and build number? Is it actually the new firmware running or an old version?
