Highlighted
HP 5130 and HP 1950 IRF Upgrade
Hi guys,
I did some upgrade on the following comware switches HP 5130 and HP1950. Both were stacked using HP IRF stacking technology. In following with the recommended upgrade instruction I rebooted the two switch in each stack of two together as recommended. During the upgrade, we lost the servers connected to the switch stack.
My question is, Can each member of the switch stack be rebooted independently instead of rebooting both so that we don't loose server connection during the upgrade?
//Collins
Highlighted
MVP Guru Elite
Re: HP 5130 and HP 1950 IRF Upgrade
It is not possible on this switch
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Hi Alexis,
Do you mean on both switch model? HP 5130 and HP 1950?
//Collins
Highlighted
MVP Guru Elite
Yes,
There is no ISSU on this switches
