Frequent Contributor I
HPE 1920 Inter VLAN routing
Does HPE 1920S support inter vlan routing.
If yes could guide me to get rought idea how to go through .
MVP
MVP
Re: HPE 1920 Inter VLAN routing
Nope it dont
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
MVP
MVP
Hmm now iam not sure 1920 is diffrent as the 1920s.
You can test it... maybe got only the gui but some like to break in the cli ;)
Below an cli example tongive some idea.
Vlan 1
Vlan 2
Interface vlan-interface 1
Ip address 192.168.1.254 255.255.255.0
Interface vlan-interface 2
Ip address 192.168.2.254 255.255.255.0
Ip routing
Hi Mkk,
Thank you for support
HPE 1920S support  Intervlan routing as well as 1920. I gave remote support for my customer to configure inter vlan routiung. I failed ther because due ICMP blocked in customer end device.
