Highlighted
HPE OfficeConnect 1920s and FreeRADIUS
Hi everyone,
I'm trying to get the switch work together with the freeradius.
The radius itself works fine with a cisco switch and does it job so i guess I'm missing something in the 1920s config.
The switch runs with software version PD.02.10.
Under Security ---> RADIUS
I enabled both 802.1x Auth and Acc Mode and added the IP and Secret for the radius (for both the Auth- and Acc-Server) and as NAS-IP Address i also entered the RADIUS IP.
Under Security ---> Port Access Control
I enabled EAPOL Flood Mode. I didn't changed the interfaces.
Under Security ---> Port Security ---> Global
The Admin Mode is still disabled and I didn't configured any interfaces either.
I think I have to enable the Admin Mode for Port Access Control to get it working? If so can I do it without denying the access for the devices which are connected to specific ports?
Michael
