How To Get HP VSF Detail Through OID
MVP Expert
MVP Expert
Q:
How to get HP VSF detail through OID ?
A:
HP-VSF-VC-MIB
Defined Values
hpicfVsfVCMIB 1.3.6.1.4.1.11.2.14.11.5.1.116
This MIB module describes the objects that are used to manage VSF Virtual Chassis feature.
MODULE-IDENTITY
hpicfVsfVCNotifications 1.3.6.1.4.1.11.2.14.11.5.1.116.0
OBJECT IDENTIFIER
hpicfVsfVCObjects 1.3.6.1.4.1.11.2.14.11.5.1.116.1
OBJECT IDENTIFIER
hpicfVsfVCConfig 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1
OBJECT IDENTIFIER
hpicfVsfVCStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2
OBJECT IDENTIFIER
hpicfVsfVCDomainId 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.1
The VSF virtual chassis domain ID uniquely identifies the VSF virtual chassis; all members of the virtual chassis have
the same virtual chassis domain ID. The VSF virtual chassis domain ID is valid only when
hpicfVsfVCSwitchAdminStatus is set to true (1). This value is set by the first elected commander of the VSF virtual
chassis.
OBJECT-TYPE
Unsigned32
hpicfVsfVCOperStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.2
This is the current operational status of the VSF virtual chassis.
OBJECT-TYPE
INTEGER
unAvailable(0), disabled(1), active(2),
fragmentInactive(3),
fragmentActive(4)
hpicfVsfVCAdminStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.3
The administrative status of the VSF virtual chassis. When set to enable (1), this object enables VSF on the switch and
on the discovered members. Setting this to disable (2) disables VSF only on the standalone switch. Enabling or
disabling VSF triggers a reboot of the VSF switch.
OBJECT-TYPE
INTEGER enable(1), disable(2)
hpicfVsfVCTopology 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.4
This object describes the physical topology of the VSF virtual chassis.
OBJECT-TYPE
INTEGER unknown(0), chain(1), ring(2),
mesh(3), partialMesh(4)
hpicfVsfVCTrapEnable 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.5
This object controls the ability of the VSF virtual chassis to send traps.
OBJECT-TYPE
hpicfVsfVCOobmMADEnable 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.6
This object enables the VSF OOBM MAD (Multi-Active Detection) feature.
OBJECT-TYPE
hpicfVsfLldpMADEnable 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.7
This object enables the VSF LLDP MAD (Multi-Active Detection) feature.
OBJECT-TYPE
hpicfVsfVCLldpMADDeviceIpType 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.8
This object provides the address type of the VSF LLDP MAD (Multi-Active Detection)device.
OBJECT-TYPE
InetAddressType
hpicfVsfVCLldpMADDeviceIpAddr 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.9
This object provides the IPv4/IPv6 address of the VSF LLDP MAD (Multi-Active Detection) device.
OBJECT-TYPE
InetAddress
hpicfVsfVCLldpMADSnmpVersion 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.10
This object provides the VSF LLDP MAD (Multi-Active Detection) SNMP version.
OBJECT-TYPE
INTEGER v2c(2)
hpicfVsfVCLldpMADSnmpCommunity 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.11
This object provides the VSF LLDP MAD (Multi-Active Detection) SNMP community-string.
OBJECT-TYPE
STRING Size(0..255)
hpicfVsfMADVlan 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.12
This object configures the VLAN as a Multi-Active Detection (MAD) VLAN. The MAD VLAN will be used to send
and receive discovery packets to detect virtual chassis fragments in case of a split. The default value (0) of the object
indicates that no MAD VLAN is currently configured.
OBJECT-TYPE
Integer32 0..4094
hpicfVsfMADVlanConnectivity 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.13
This object indicates the connectivity state of Multi- Active-Detection (MAD) VLAN. none (1) - When the MAD
VLAN does not have any operational port in all member switches. full (2) - When the MAD VLAN has one up port in
all member switches. partial (3) - When the MAD VLAN has some up ports but does not have an operational port in all
member switches.
OBJECT-TYPE
INTEGER none(1), full(2), partial(3)
hpicfVsfVCPortSpeed 1.3.6.1.4.1.11.2.14.11.5.1.116.1.1.14
This object is used to set the speed of all VSF ports. If this object is not set, it is automatically set to the maximum
speed of the first link port added to the VSF. The value none(0) indicates that no VSF links have been added so the
speed is unknown.
OBJECT-TYPE
INTEGER none(0), oneGbps(1), tenGbps(2),
fortyGbps(3)
hpicfVsfVCLldpMADReadinessStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.1
This object indicates the readiness state of VSF LLDP MAD (Multi-Active Detection).
OBJECT-TYPE
INTEGER none(0), success(1), failure(2)
hpicfVsfVCLldpMADDeviceMAC 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.2
This object indicates the MAC address of the VSF LLDP MAD (Multi-Active Detection) helper-device.
OBJECT-TYPE
STRING Size(06)
hpicfVsfVCLldpMADVlanId 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.3
This object indicates the VLAN-ID of the domain on which the VSF LLDP MAD (Multi-Active Detection) helperdevice
resides.
OBJECT-TYPE
Integer32 1..4095
hpicfVsfVCLldpMADTrunkIfIndex 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.4
This object indicates the trunk ifIndex of the interface on the VSF device that is connected to the VSF LLDP MAD
OBJECT-TYPE
InterfaceIndexOrZero
hpicfVsfVCLldpMADProbePortSet 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.5
This object indicates the list of physical ports on the VSF LLDP MAD (Multi-Active Detection) helper-device that will
be probed for operational status during MAD probe.
OBJECT-TYPE
PortList
hpicfVsfVCLldpMADConnectivity 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.6
This object indicates the reachability state of the VSF LLDP MAD (Multi-Active Detection) helper-device. none (1) -
When there is no connectivity to the LLDP MAD helper-device. full (2) - When the LAG has at least one physical port
in the enabled state on every VSF member switch. partial (3) - When the LAG does not have at least one enabled VSF
physical port on every VSF member switch.
OBJECT-TYPE
hpicfVsfVCLldpMADSplitStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.7
This object indicates the VSF LLDP MAD (Multi-Active Detection) split status.
OBJECT-TYPE
INTEGER yes(1), no(2)
hpicfVsfVCLldpMADProbeOriginator 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.8
This object indicates whether the VSF fragment is running the VSF LLDP MAD (Multi-Active Detection) probe or not.
OBJECT-TYPE
hpicfVsfVCLldpMADProbeRequestsSent 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.9
This is the number of SNMP queries sent to the VSF LLDP MAD (Multi-Active Detection) helper-device.
OBJECT-TYPE
Counter32
hpicfVsfVCLldpMADProbeResponseRcvd 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.10
This is the number of SNMP responses received from the VSF LLDP MAD (Multi-Active Detection) helper-device.
OBJECT-TYPE
Counter32
hpicfVsfVCLldpMADActiveFragment 1.3.6.1.4.1.11.2.14.11.5.1.116.1.2.11
This object specifies whether this VSF fragment is the active or an inactive fragment.
OBJECT-TYPE
hpicfVsfVCMemberTable 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3
This table contains information about the VSF virtual chassis members.
OBJECT-TYPE
SEQUENCE OF
HpicfVsfVCMemberEntry
hpicfVsfVCMemberEntry 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1
A row in the VSF virtual chassis member table.
OBJECT-TYPE
hpicfVsfVCMemberId 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.1
This object describes the VSF virtual chassis member ID.
OBJECT-TYPE
Integer32 1..65535
hpicfVsfVCMemberProductId 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.2
This object describes the type of VSF member-switch.
OBJECT-TYPE
DisplayString
hpicfVsfVCMemberMacAddr 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.3
This object specifies the VSF member-switch MAC address.
OBJECT-TYPE
STRING Size(06)
hpicfVsfVCMemberShutdown 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.4
When this object is set to true (1) for a specific active-member VSF virtual chassis switch, that switch will shut down.
Setting the object to false (2) has no effect. This object cannot be set to true (1) if the specified member is an VSF
commander. If the VSF member is in standby mode, a new standby switch is chosen. The VSF member shutdown is
prevented if it will cause a virtual chassis split.
OBJECT-TYPE
TruthValue
hpicfVsfVCMemberReboot 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.5
When set to true (1), this object will reboot the VSF member-switch. Setting the object to false (2) has no effect. Reboot
is prevented if it will cause a virtual chassis split.
OBJECT-TYPE
TruthValue
hpicfVsfVCMemberAdminPriority 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.6
This object allows the user to set the priority of a switch when VSF is enabled on it.
OBJECT-TYPE
Integer32 1..255
hpicfVsfVCMemberEntryStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.7
This object indicates the row status of an VSF virtual chassis-member entry. If the VSF member ID corresponds to an
VSF commander, the row cannot be destroyed. For active switches, if hpicfVsfVCMemberReboot is set to true (1), and
the row status is set to destroy (6), the switch comes up with a default configuration and acquires a new
hpicfVsfVCMemberId.
OBJECT-TYPE
RowStatus
hpicfVsfVCMemberEntPhysicalIndex 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.8
This object specifies the entPhysicalTable (rfc2737) index of the VSF member.
OBJECT-TYPE
PhysicalIndex
hpicfVsfVCMemberState 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.9
hpicfVsfVCMemberProductName 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.10
The product name of the VSF member-switch.
OBJECT-TYPE
SnmpAdminString
hpicfVsfVCMemberUpTime 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.11
This object provides the uptime of the VSF member-switch. This is different from the VSF chassis uptime.
OBJECT-TYPE
TimeTicks
hpicfVsfVCMemberSysOid 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.12
This object provides the sysObjectId of the VSF member-switch.
OBJECT-TYPE
OBJECT IDENTIFIER
hpicfVsfVCMemberIdForTrap 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.13
The member ID used in trap notifications. This is the same value as hpicfVsfVCMemberId.
OBJECT-TYPE
Integer32
hpicfVsfVCMemberSerialNum 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.14
This object specifies the serial number of the VSF member-switch.
OBJECT-TYPE
DisplayString
hpicfVsfVCMemberBootRomVersion 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.15
This object specifies the boot-ROM version of the VSF member-switch.
OBJECT-TYPE
DisplayString
hpicfVsfVCMemberOsVersion 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.16
This object specifies the operating system version of the VSF member-switch.
OBJECT-TYPE
DisplayString
hpicfVsfVCMemberBootImage 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.17
This object specifies the boot image of the VSF member-switch.
OBJECT-TYPE
INTEGER primary(1), secondary(2)
hpicfVsfVCMemberRenumber 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.18
This object specifies the new member ID to be assigned to this VSF virtual chassis member-switch.
OBJECT-TYPE
Integer32
hpicfVsfVCMemberCpuUtil 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.19
This object provides the percentage of CPU utilization of the VSF member-switch.
OBJECT-TYPE
Integer32
hpicfVsfVCMemberTotalMemory 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.20
This object provides the total memory usage in bytes of the VSF member-switch.
OBJECT-TYPE
Integer32
hpicfVsfVCMemberFreeMemory 1.3.6.1.4.1.11.2.14.11.5.1.116.1.3.1.21
This object provides the free memory available, in bytes, on the VSF member-switch.
OBJECT-TYPE
Integer32
hpicfVsfVCLinkTable 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4
This table contains information about the VSF links. An VSF link is a logical interface for the connection between VSF
member devices. To use an VSF link, you must bind at least one physical port to it. These ports are called 'VSF physical
ports' or 'VSF Ports'. The physical ports assigned to an VSF link automatically form an aggregate VSF link. An VSF
link goes down only if all of its members' physical ports are down.
OBJECT-TYPE
SEQUENCE OF
HpicfVsfVCLinkEntry
hpicfVsfVCLinkEntry 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1
A row in the VSF link table.
OBJECT-TYPE
HpicfVsfVCLinkEntry
hpicfVsfVCLinkMemberId 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.1
This object is the member ID of the VSF virtual chassis to which this VSF link belongs.
OBJECT-TYPE
Integer32 1..65535
hpicfVsfVCLinkId 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.2
This object indicates the link ID for this VSF entry.
OBJECT-TYPE
Integer32 1..4
hpicfVsfVCLinkName 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.3
This object indicates the VSF link name. The maximum allowed link name is 32 characters.
OBJECT-TYPE
DisplayString Size(0..100)
hpicfVsfVCLinkOperStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.4
This object indicates the VSF link state.
OBJECT-TYPE
INTEGER up(1), down(2), disabled(3)
hpicfVsfVCPeerMemberId 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.5
This object indicates the peer-member ID to which the VSF link is connected.
OBJECT-TYPE
Integer32
hpicfVsfVCPeerLinkId 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.6
This object indicates the VSF link ID of the peer-member to which this VSF link is connected.
OBJECT-TYPE
Integer32
hpicfVsfVCLinkPortList 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.7
This object indicates the list of physical ports belonging to this VSF link.
OBJECT-TYPE
PortList
hpicfVsfVCLinkEntryStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.8
This object indicates the row status of an VSF virtual chassis link entry.
OBJECT-TYPE
RowStatus
hpicfVsfVCLinkIdForTrap 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.9
This object indicates the VSF virtual chassis link ID used in trap notifications. This is the same value as
hpicfVsfVCLinkId.
OBJECT-TYPE
Integer32
hpicfVsfVCLinkPortStartState 1.3.6.1.4.1.11.2.14.11.5.1.116.1.4.1.10
This object indicates whether ports should be enabled while creating the VSF virtual chassis link.
OBJECT-TYPE
hpicfVsfVCPortTable 1.3.6.1.4.1.11.2.14.11.5.1.116.1.5
This table contains information about the VSF virtual chassis physical ports.
OBJECT-TYPE
SEQUENCE OF
HpicfVsfVCPortEntry
hpicfVsfVCPortEntry 1.3.6.1.4.1.11.2.14.11.5.1.116.1.5.1
A row in the VSF port table.
OBJECT-TYPE
HpicfVsfVCPortEntry
hpicfVsfVCPortOperStatus 1.3.6.1.4.1.11.2.14.11.5.1.116.1.5.1.1
This object provides the VSF virtual chassis physical port state.
OBJECT-TYPE
INTEGER up(1), down(2), error(3), disabled(4),
provisioned(5)
hpicfVsfVCPortOperStatusErrorStr 1.3.6.1.4.1.11.2.14.11.5.1.116.1.5.1.2
This object provides an error message if hpicfVsfVCPortOperStatus returns the value error (3).
OBJECT-TYPE
DisplayString
hpicfVsfVCCommanderChange 1.3.6.1.4.1.11.2.14.11.5.1.116.0.2
This notification is generated when a new VSF commander first comes up. The notification is also sent when a failover
happens, and the VSF standby becomes an VSF commander or when the VSF commander is down.
NOTIFICATION-TYPE
hpicfVsfVCMemberChange 1.3.6.1.4.1.11.2.14.11.5.1.116.0.3
This notification is generated when a new member joins the VSF virtual chassis or when a member switch is moved
from the loose-provisioned state to the strict-provisioned state.
NOTIFICATION-TYPE
hpicfVsfVCMemberStatusChange 1.3.6.1.4.1.11.2.14.11.5.1.116.0.4
This notification is generated when an VSF member becomes active or inactive.
NOTIFICATION-TYPE
hpicfVsfVCConformance 1.3.6.1.4.1.11.2.14.11.5.1.116.2
OBJECT IDENTIFIER
hpicfVsfVCCompliances 1.3.6.1.4.1.11.2.14.11.5.1.116.2.1
OBJECT IDENTIFIER
hpicfVsfVCGroups 1.3.6.1.4.1.11.2.14.11.5.1.116.2.2
OBJECT IDENTIFIER
hpicfVsfVCConfigScalarGroup 1.3.6.1.4.1.11.2.14.11.5.1.116.2.2.1
A collection of VSF virtual chassis scalar objects.
OBJECT-GROUP
hpicfVsfVCMemberTableGroup 1.3.6.1.4.1.11.2.14.11.5.1.116.2.2.2
A collection of VSF virtual chassis member table objects.
OBJECT-GROUP
hpicfVsfVCLinkTableGroup 1.3.6.1.4.1.11.2.14.11.5.1.116.2.2.3
A collection of VSF virtual chassis link table objects.
OBJECT-GROUP
hpicfVsfVCNotificationsGroup 1.3.6.1.4.1.11.2.14.11.5.1.116.2.2.4
A collection of VSF virtual chassis notifications objects.
NOTIFICATION-GROUP
hpicfVsfVCStatusScalarGroup 1.3.6.1.4.1.11.2.14.11.5.1.116.2.2.5
OBJECT-GROUP
hpicfVsfVCPortTableGroup 1.3.6.1.4.1.11.2.14.11.5.1.116.2.2.6
A collection of VSF virtual chassis physical port objects.
OBJECT-GROUP
hpicfVsfVCConfigScalarGroup1 1.3.6.1.4.1.11.2.14.11.5.1.116.2.2.7
OBJECT-GROUP
hpicfVsfVCMibCompliance 1.3.6.1.4.1.11.2.14.11.5.1.116.2.1.1
The compliance statement for devices implementing the HP VSF VC Mib.
MODULE-COMPLIANCE
hpicfVsfVCMibCompliance1 1.3.6.1.4.1.11.2.14.11.5.1.116.2.1.2
MODULE-COMPLIANCE
Version history
Revision #:
1 of 1
Last update:
‎03-29-2019 02:03 PM
Updated by:
