How To Properly Set Console Baud Rates For AOS-Switch Versus AOS-CX
MVP
MVP
Q:
A:
AOS-Switch
Switches running AOS-Switch Code will output boot messages at 9600 baud only
After boot up, the switch console port will then speed sense up to 115200 baud
AOS-CX
For switches running AOS-CX code, the baud rate is fixed at 115200.
CABLE PART NUMBERS
DB9 to RJ45 Console Cable:  5300-0357
RJ45--DB9 Console Port Adapter For AOS-Switch:  5189-6795
NOTE:
Using an incorrect baud rate setting and/or a non-HPE cable can result in
  • Blank Screen During Boot Up
  • No Response When Hitting CR
  • Characters And Other Garbled Output
Review The Switches Basic Operation Guide For Additional Information and Settings
Version history
Revision #:
2 of 2
Last update:
‎10-29-2019 08:26 AM
Updated by:
Contributors
