How To Set BGP Authentication Password
MVP
MVP
Problem:
BGP peer status is stuck in Active state:
R1(config)# show ip bgp summary
Peer Information
 Remote Address    Remote-AS   Local-AS   State        Admin Status
 20.1.1.2                    777                  6500       Active         Start
Diagnostics:
Check the BGP configuration on both routers
R1(config)# show run
router bgp 6500
enable
neighbor 20.1.1.2 remote-as 777
exit
R2(config)# show run
router bgp 777
enable
neighbor 20.1.1.3 remote-as 6500
neighbor 20.1.1.3 encrypted-password "JzkUaVbNITb00vghOnMa8qaIJUCs1SrML7Ur1ytsdS8="
exit
Solution
R1 has no BGP password configured, R2 password does.  Therefore, BGP peer is stuck in Active state.
You have to configure Password on both the routers.  Router 1 is updated below:
R1(config)# router bgp 6500
neighbor 20.1.1.2 password abcdefgh1234
router bgp 6500
enable
neighbor 20.1.1.2 encrypted-password "JzkUaVbNITb00vghOnMa8qaIJUCs1SrML7Ur1ytsdS8="
exit
router bgp 777
enable
exit
Check the router is no longer stuck in Active state
Peer Information
 20.1.1.2                    777                  6500       Established         Start
Version history
Revision #:
1 of 1
Last update:
‎01-27-2020 08:36 AM
Updated by:
