How To Setup Additional Commands For User-Level 1
MVP Expert
MVP Expert
By default on Comware v5 switches, limited command is available to use at User-level 0, 1 & 2.
Command level falls into four levels: visit (0), monitor(1), system (2) and manage (3). The administrator can assign a privilege level for a user according to the user’s need.
The command-privilege command is used to assign a level for the specified command in a specified view.
We will add following commands to User-level 1 on the switch:
  • display current-configuration
  • display saved-configuration
  • dir
  • display boot-loader
User with level 1 privilege logs in to the switch:
<SW1>display current-configuration
% Unrecognized command found at '^' position.
<SW1>display saved-configuration
<SW1>dir
<SW1>display boot-loader
Login to switch with user-privilege 3 and perform the below operations:
Enter system view and configure the desired commands:
 <SW1>system-view
 System View: return to User View with Ctrl+Z.
 [SW1] command-privilege level 1 view system display current-configuration
 [SW1] command-privilege level 1 view system display saved-configuration
 [SW1] command-privilege level 1 view shell dir
 [SW1] command-privilege level 1 view system display boot-loader
 [SW1]quit
Login to switch with user-privilege 1 and test the commands:
<SW1>dir
 Directory of flash:/
    0     -rw-   8876183  Oct 31 2019 04:51:52   logfile.log
    1    -rw-  21372116  Oct 31 2019 18:22:37   s5800_5820x-cmw520-r1110p06.bin
  version 5.20, Release 1211P06
  sysname SW1
  command-privilege level 1 view user-interface display boot-loader
return
Slot 1
 The current boot app is:  flash:/a5800_5820x-cmw520-r1211p06.bin
 The main boot app is:     flash:/a5800_5820x-cmw520-r1211p06.bin
Version history
Revision #:
1 of 1
Last update:
a week ago
Updated by:
