How To Turn On BGP Neighbor Adjacency Changes On Aruba Switches
MVP Expert
MVP Expert
How to have Aruba HPE switches to log BGP neighbor adjacency changes
Aruba switches by default would not log BGP neighbor adjacency changes , either neighbor going UP or neighbor going DOWN.
This can be verified by the following command:
  Aruba-Stack-3810M #show ip bgp general
  Log Neighbor Changes  : No
  *some output omitted.
So if an Aruba HPE switch loses BGP neighbor adjacency with any neighbor switch, the "show log -r" command woll not reveal this event.
This behavior can be altered so the switch can log BGP neighbor state changes.
To turn on logging for BGP adjacency changes , go to bgp context and run the following command
Aruba-Stack-3810M (config)#router bgp <as.no>
Aruba-Stack-3810M(bgp)# bgp log-neighbor-changes
To verify run the following command:
Log Neighbor Changes  : Yes
If we tear down a Router BGP adjacency, the logs now show this information:
show log Aruba-Stack-3810M #show log  -r
W 07/02/19 09:42:15 03073 bgp: 10.1.1.2: Peer down
Version history
Revision #:
1 of 1
Last update:
‎08-23-2019 02:45 PM
Updated by:
