To see a comprehensive view of how many ACL's you can have you can use the following command:
SWITCH# show access-list resource
Solution:SWITCH# show access-list resource
HP-Switch-5412Rzl2# show access-list resource
Resource usage in Policy Enforcement Engine
Ingress Policy Enforcement Engine Rules
| Rules | Rules Used
Slots | Available | ACL | QoS | IDM | VT | Mirr | PBR | OF | Other |
A | 8166 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 6 |
B | 8166 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 6 |
Ingress Policy Enforcement Engine Meters
| Meters | Meters Used
A | 2046 | | 0 | 0 | 0 | | | 0 | 0 |
B | 2046 | | 0 | 0 | 0 | | | 0 | 0 |
Ingress Policy Enforcement Engine Port Ranges
|Application|
|Port Ranges| Application Port Ranges Used
A | 60 | 0 | 0 | 0 | | 0 | 0 | 0 | 0 |
B | 60 | 0 | 0 | 0 | | 0 | 0 | 0 | 0 |
Ingress Policy Enforcement Engine PBR Resources
| PBR |
| Next-hops | PBR Next-hops Used
A | 1024 | | | | | | 0 | | 0 |
B | 1024 | | | | | | 0 | | 0 |
4 of 32 Policy Engine management resources used.
Key:
ACL = Access Control Lists
QoS = Device & Application Port Priority, QoS Policies, ICMP rate limits
IDM = Identity Driven Management
VT = Virus Throttling blocks
Mirr = Mirror Policies, Remote Intelligent Mirror endpoints
PBR = Policy Based Routing Policies
OF = OpenFlow
Other = Management VLAN, DHCP Snooping, ARP Protection, Jumbo IP-MTU,
RA Guard, Control Plane Protection, Service Tunnel, ND Snooping, UWW,
mDNS, tunneled-node-server, copp, ICMP rate-limit,
Unknown Unicast rate-limit.
Resource usage includes resources actually in use, or reserved for future
use by the listed feature. Internal dedicated-purpose resources, such as
port bandwidth limits or VLAN QoS priority, are not included.
Configuration:SWITCH# show access-list resource
| Rules | Rules Used
|Application|
| PBR |
Key:
OF = OpenFlow
