How is the Out-of-Band Management Port (OOBM) Configured and Used?
MVP Expert
MVP Expert
Q:
How is the Out-of-Band management port (OOBM) configured and used?
A:
In the following example, the Out-of-Band management port is configured to acquire an IP address via DHCP. IP connectivity and a file copy from a TFTP server is tested.
********** OOBM Configuration **********
Rack2sw1(config)# oobm ip address dhcp
Rack2sw1(config)# oobm enable
********** Display the OOBM enable status **********
Rack2sw1# show oobm
 Global OOBM Configuration
  OOBM Enabled           : Yes
  OOBM Port Type         : 10/100TX
  OOBM Interface Status  : Up
  OOBM Port              : Enabled
  OOBM Port Speed        : Auto
  MAC Address            : 941882-a36541
********** OOBM IPV4 Verification **********
Rack2sw1# show oobm ip
  IPv4 Status          : Enabled
  IPv4 Default Gateway : 10.181.25.254
        |                                     Address  Interface
 Member | IP Config IP Address/Prefix Length  Status   Status
 Global | dhcp      10.181.25.129/24                   Up
********** Ping testing a TFTP server at the IP address 10.181.252.102 **********
Rack2sw1# ping 10.181.252.102 source oobm
10.181.252.102 is alive, time = 3 ms
********** Copy Firmware File to Flash **********
Rack2sw1# copy tftp flash 10.181.252.102 WB_16_08_0001.swi secondary oobm
The secondary image will be deleted.
Continue (y/n)? y
Rack2sw1# show flash
Image             Size (bytes) Date     Version
Primary Image    :    16464572 07/21/17 WB.16.04.0008
Secondary Image  :    16976865 11/21/18 WB.16.08.0001
Version history
Revision #:
1 of 1
Last update:
‎01-07-2019 10:26 AM
Updated by:
