Q:
How to exclude ip address from DHCP pool on 1950 switches (JG962A).
No options are available on the web interface on the 1950 switches to exclude the ip address from the dhcp server.
there is no option to exclude ip address from the dhcp server on the 1950 switches via the web interface for the customer.
You can use the cmd line mode to make the configuration changes on the switch by breaking through the cli.
Excluding the ip on the dhcp pool is not an option available on the 1950 however we can forbid the ip on the dhcp server so that it will not assign that ip to any request.
you forbid up to 15 ip address on the dhcp server pool on the switch.
