How to force VLAN interface to stay always UP?
Hello, experts
Is it possible to force a VLAN interface with a command to remain always up, even if no equipment is connected to the switch?
Carlos Villanueva
Super Contributor I
Re: How to force VLAN interface to stay always UP?
That is not possible. If this is needed for management purposes use loopback interfaces.
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
Thanks, Willem.
MVP Expert
Tagging that VLAN Id to a port used for an uplink (so the port is necessarily in up state with the uplink connected)...it's a way.
