Wired Intelligent Edge
How to put in default mode an interface
This thread has been viewed 27 times
  • 1.  How to put in default mode an interface
    Posted Feb 27, 2019 05:29 AM
    Hi All,
    I would like to know how to put in default mode an interface, like cisco got the "default" command, which command in AOS put an interface in default mode, it exist this command?
  • 2.  RE: How to put in default mode an interface
    MVP GURU
    Posted Feb 27, 2019 10:59 AM
    @enlusa wrote:
    Hi All,
    on the ArubaCX or Aruba (2930F, 3810...)
  • 3.  RE: How to put in default mode an interface
    Posted Feb 28, 2019 06:14 AM
    Hi @alagoutte
  • 4.  RE: How to put in default mode an interface
    MVP GURU
    Posted Feb 28, 2019 07:15 AM
    @enlusa wrote:
    Hi @alagoutte
    It is not possible
  • 5.  RE: How to put in default mode an interface
    Posted Feb 28, 2019 09:56 AM
    Like @alagoutte mentions, this is not possible.
    You have to "no" all commands. If a command isn't deleted via the "no" version of the command, it means you have to enter the default value to remove the command from the configuration.
    Example:
    To remove the command "aaa port-access authenticator 1/1 tx-period 10" you have to configure the default value of the command, which is 30
    aaa port-access authenticator 1/1 tx-period 30
  • 6.  RE: How to put in default mode an interface
    Posted Mar 01, 2019 12:11 PM
    Yeah, you have to undo most of the config.
    If it was comware, there is an default command since most interface config is done at the interface.
    For Aruba OS switch, some interface config is done at vlan level, hence why this don't seem possible.
    However, when I need to undo commands, getting the right show commands is always a problem. I normally use 'show config int n', but there are others you can explore. Please see the link below for some other suggestions.
    https://h22208.www2.hpe.com/eginfolib/networking/docs/switches/common/15-18/5998-8158_bog/content/ch04s09.html
    (Sorry, document is quite old, but it's saved as my shortcut ;-) )
  • 7.  RE: How to put in default mode an interface
    Posted Mar 01, 2019 12:46 PM
    Greetings!
    Here is the current version of that section.
  • 8.  RE: How to put in default mode an interface
    Posted Mar 06, 2019 11:37 PM
    Hello enlusa,
    First of all there is no single command like to make the interface to its default settings.
    You need to go to the interface configuration mode and then
    1. Undo the configuration by putting "no"  in front of present command
    2. There are some POE Configuration which will not be removed by no "command" and you need to set the default value to make it removed.
    If you share the configuration, I can help you to configure the interface as default.
    In case if you satisfied with answer - press kudos
