Highlighted
How to rout between vlans in Aruba 2530-48G by web interface ?
Hi all,
I have 3 switchs Aruba 2530-48G and one router Dektec300B. I already tested creating some vlans and it is done. Now i want a vlan (belong to  a vlan)  to be able to access to another. How can i do that in webinterface (i am newbie so cannot use cli)?
Thanks alot.
Highlighted
MVP Expert
Re: How to rout between vlans in Aruba 2530-48G by web interface ?
Greetings!
The 2530 is a Layer 2-only switch, and as such does not support inter-VLAN routing. You would need to tag the VLANs across the uplink to the router and configure it to perform any desired routing there.
Matt Fern
Senior Technical Marketing Engineer, Aruba Switching
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
