IPv6 prefix delegation client on 2930F
Hey Folks,
I am trying to set up an Aruba 2930F as the core router of my home network. I have a modem, provided by my ISP, which is doing DHCPv4 and NAT and also DHCPv6 with prefix delegation and routing. I have several VLANs for Iot, Guests, Clients, etc and I want the 2930F to use PD to request /64 prefixes for the different VLANs from the IPS modem. I enabled IPv6 and dhcp-client on the uplink vlan and the switch recieves a propper ip address with the correct subnet size, but how do I configure PD for the other VLANs?
I already looked into this document, but haven't found anything:
https://support.hpe.com/hpsc/doc/public/display?docId=a00050248en_us
Any help would be apreciated!
Kind Regards,
Hendrik
WiFi Enthusiast | ACMP
MVP Guru
Re: IPv6 prefix delegation client on 2930F
I have not seen prefix-delegation on the ArubaOS switches and would see that more as a router feature than in an (L3) switch.
Reach out to your Aruba sales team to verify if the feature may be on the short term roadmap. Aruba partners can also open feature requests.
