Highlighted
Contributor II
Interface uptime
Hi, does any one know if there is a command to see since when an interface is in the current status?
For example, if I want to know since when interface 1 is up (or down).
Thanks.
Highlighted
Contributor II
Re: Interface uptime
I can't find a CLI command for that but you can see through SNMP the uptime of the switch when the port changed state for the last time.
The OID is .1.3.6.1.2.1.2.2.1.9 - ifLastChange:
The value of sysUpTime at the time the interface entered
its current operational state. If the current state was
entered prior to the last re-initialization of the local
network management subsystem, then this object contains a
zero value.
Hope this helps.
Best regards,
Aarón
Highlighted
Contributor II
Thank you for your reply.
I also didn't find a way to obtain this information other than checking the switch's log or an external server that collects SNMP traps.
I thought getting such basic information would be more straightforward and simple.
Highlighted
MVP Guru Elite
for ArubaOS or ArubaCX ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Contributor II
ArubaOS, I have a 2530 and a 2930F in my lab at the moment.
