Highlighted
Issues with RIPv2 in ArubaOS Switch
Guys, im facing an issue here in one deployment in Workbench... the customer ask me to compare the ArubaOS switch Features with the Cisco IOS.. they are searching for another vendor and they provide us the testing procedure dossiers to fullfill with the Cisco commands and features to translate do the ArubaOS switch configuration.
I am using the KB.16.05.0003 version that is available in the Workbench and i have configured the following:
Switch A:
ip routing
interface loopback 0
ip address 192.168.0.1
router rip
redistribute connected
enable
exit
vlan 99
name "VLAN99"
untagged 1
ip address 192.168.3.1 255.255.255.0
ip rip 192.168.3.1
exit
Switch B:
ip routing
ip address 192.168.1.1
router rip
enable
exit
vlan 99
name "VLAN99"
untagged 1
ip address 192.168.3.2 255.255.255.0
ip rip 192.168.3.2
exit
After i apply both configs i cant see any information about the RIP peer:
Switch1# show ip rip
RIP global parameters
RIP protocol : Enabled
Auto-summary : Enabled
Default Metric : 1
Distance : 120
Route changes : 0
Queries : 0
RIP interface information
IP Address Status Send mode Recv mode Metric Auth
192.168.3.1 Enabled V2-only V2-only 1 none
RIP peer information
IP Address Bad routes Last update timeticks
Switch2# show ip rip
Default Metric : 1
Distance : 120
Route changes : 0
Queries : 0
192.168.3.2 Enabled V2-only V2-only 1 none
But after i apply the "no router rip auto-summary" in both switches everything works:
Auto-summary : Disabled
Default Metric : 1
Distance : 120
Route changes : 1
Queries : 0
192.168.3.2 0 28
Default Metric : 1
Distance : 120
Route changes : 1
Queries : 0
192.168.3.1 0 9
Switch1# show ip route
IP Route Entries
Destination Gateway VLAN Type Sub-Type Metric Dist.
127.0.0.0/8 reject static 0 0
127.0.0.1/32 lo0 connected 1 0
192.168.0.1/32 lo0 connected 1 0
192.168.1.1/32 192.168.3.2 99 rip 2 120
192.168.3.0/24 VLAN99 99 connected 1 0
Switch2# show ip route
IP Route Entries
192.168.0.1/32 192.168.3.1 99 rip 2 120
192.168.1.1/32 lo0 connected 1 0
My problem is.. the customer want to use the auto-summary feature... there is anything that i can do to solve this?
Thanks in advance :)
