Frequent Contributor I
JL563A Compatibility with ArubaOS switch
Does Aruba 10G Copper  transceiver support with Aruba 2930M/3810M switch.
MVP Expert
Re: JL563A Compatibility with ArubaOS switch
Question: Is JL563A 10G Copper Transceiver supported by Aruba 2930M and/or Aruba 3810M Switch series?
Answer: No, it isn't.
Reference here:
thank you...
