Highlighted
Frequent Contributor II
LACP Timings on 5412Rzl2
Is there any command to set the LACP timings to fast and change the timeout value on HP5400Rzl2?
On Aruba wifi controller there is a command to change the timeout value from long (90sec) to short (3sec)
Accepted Solutions
Highlighted
MVP Guru
Re: LACP Timings on 5412Rzl2
AFAIK on ArubaOS-Switch (HP ProVision) OS based Switches is not possible to configure Short LACPDU timing and the Local LACP Timer (Fast or Short it is...check with show lacp local) you see is requested by the LACP partner and can't be changed (short/long or fast/slow).
On Comware OS based Switches you can set the LACPDU timings.
View solution in original post
All Replies
Highlighted
MVP Guru
