Layer 3 traffic not working across 8325 ISL link
I am unable to send layer 3 traffic across an ISL link for a specific VLAN using 8325 switches using v10.03.0040 firmware. For instance i can't ping from VLAN 2 on the primary switch to VLAN 2 on the secondary switch, and vice versa.
Trying to ping from switch 2 CLI to switch 1 VLAN 2:
# ping 10.2.1.2
PING 10.2.1.2 (10.2.1.2) 100(128) bytes of data.
From 10.2.1.3 icmp_seq=1 Destination Host Unreachable
From 10.2.1.3 icmp_seq=2 Destination Host Unreachable
From 10.2.1.3 icmp_seq=3 Destination Host Unreachable
From 10.2.1.3 icmp_seq=4 Destination Host Unreachable
From 10.2.1.3 icmp_seq=5 Destination Host Unreachable
EDIT: The problem is now resolved after updating to v10.03.0070.
MVP Guru Elite
Re: Layer 3 traffic not working across 8325 ISL link
Fixed with upgrade
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
