Link aggregation for 2530-8G
Dear Community,
I have purchased a new 2530-8G PoE switch. I want to configure Link aggregation for port 1 and 2 for example.
However, in the GUI, I am not able to find the option to enable Link aggregation.
Is there any way I can configure link aggregation from the GUI?
Thank you in advance.
Rgds,
Johnson
MVP Expert
Re: Link aggregation for 2530-8G
Web Dashboard -> Interfaces -> Trunks (in HP ProVision/Aruba ArubaOS-Switch operating system jargon, links aggregation group - LAG - is ports trunking so...go to Trunks).
Thanks for the reply.
Let me confirm my understanding based on your reply.
In the "Trunk Groups" there are many trunks.
"Trk1"
"Trk2"
I will need to add 2 ge ports to "Trk1" and then this trunk will have a speed of 2000Mbit/s without additional configuration. Is that correct?
MVP Expert
"Trk1"
"Trk2"
yes, it is the idea !
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
Thank you very much for the confirmation!
