MIBs For Stacking ports Status on 3810 product line
MVP Expert
MVP Expert
Q:
What are the MIB values to see stacking port status on Aruba 3810 products?
A:
  • Stacking module in 3810 is associated with the ifIndex/ifDescr values identified as Out of Band Management Port ( ifIndex.5483 is the Stacking Link connection):
  • ifDescr.5483:
  • Stacking up and running between 2x 3810 units, ifAdminStatus.5483 and ifOperStatus.5483 are up:
  • With stacking link removed to force failure, ifAdminStatus.5483 and ifOperStatus.5483 change to down:
Version history
Revision #:
1 of 1
Last update:
‎10-03-2018 11:37 AM
Updated by:
