MTBF information for some switches
Hi all.
I am looking for the MTBF info for the some switchs:
Aruba 2920-48G Switch (J9728A)
Aruba 5406R zl2 Switch (J9821A)
Aruba 2930F 48G Switch(JL254A)
ARUBA 1920S 24G Switch
Thanks.
MVP Guru
Re: MTBF information for some switches
These are the numbers that I have:
Aruba 2920-48G Switch (J9728A):  309541 hours
Aruba 5406R zl2 Switch (J9821A): depends on the modules; chassis J9850A: 700800 hours
Aruba 2930F 48G Switch(JL254A): 565161 hours
ARUBA 1920S 24G Switch (JL381A):  700800 hours
many thanks
