Highlighted
MTU size on Cisco for Aruba GRE tunnel ?
We have some switchports on Aruba 2930 that are configured for a GRE tunnel back to our controller.
I can only place the command 'Jumbo" on the VLAN interface of the 2930.
The uplink router is Cisco router. I need to change the MTU size on the WAN interface ?
Would the proper size for the tunnel be "ip mtu 1514" ?
Or another size ?
Highlighted
MVP Guru Elite
Re: MTU size on Cisco for Aruba GRE tunnel ?
use MTU 1600
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
