Hi there,
Does the 2930F switch have the capability to mirror ports?
I am trying to monitor a port and cannot see any configuration command for it.
Quick response would be fantastic, much obliged.
Hi
You can find commands in this manual:
https://support.hpe.com/hpsc/doc/public/display?docId=a00055700en_us
page 391
Regards
PS: If this helps you, please give some kudos
You have local and remote mirrors in AOS-Switch. Since you're not specifically asking for remote mirrors I'll provide an example of a local mirror. A local mirror copies traffic to a certain destination port on the same switch. Hereby the steps:
Then you go to:
- interface <PORT/TRUNK>
- monitor all [in|out|both] mirror <SESSION> [no-tag-added]
This is the most simple version of a mirror. You have more functions to select specific traffic, remote mirror etc.
Hope this helps you!
Dobias
