Multi-Chassis LAG support for Aruba 2930M
Hi pals.
Does 2930M support Multi-Chassis LAG or a simmilar feature that permits link aggregation using ports in different members of a stack?
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
Re: Multi-Chassis LAG support for Aruba 2930M
In a stack, all the stack members act as one switch, so when you configure a standard LACP LAG that spans all stack members, you are aggregating the links across the stack.  In other words, a standard LAG will work across all members of a stack whether backplane stacking or using VSF.
This would be an example of a LAG over different stack members:
trunk 1/A1,2/A1 trk1 lacp
Justin
