Highlighted
Need to enable All access on switch via console.
Please find in attachment the modification that one of our customer have done by mistake on the web-interface of his Aruba Switch.
He has enabled the only SNMP access on it.
Do you have the list of commands that we can type directly connected on the switch in order to re-enable all accesses?
Thanks in advance for your help.
Guillaume
Accepted Solutions
Highlighted
MVP Expert
Re: Need to enable All access on switch via console.
Greetings!
If you can check the running configuration ('show running-config'), you should see a command similar to the following:
ip authorized-managers 10.40.0.65 255.255.255.0 access-method snmp
What you'll need to do is either remove that line to re-enable unrestricted access to the switch:
switch(config)# no ip authorized-managers 10.40.0.65
...or modify the command to allow full access from this subnet using all access methods:
switch(config)# ip authorized-managers 10.40.0.65 255.255.255.0 access manager access-method all
For more information, refer to the ArubaOS-Switch Hardening Guide
Matt Fern
Senior Technical Marketing Engineer, Aruba Switching
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
View solution in original post
All Replies
Highlighted
MVP Guru Elite
no ip authorized... ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
no, http access not enabled
Highlighted
MVP Expert
Greetings!
Matt Fern
Highlighted
Thank you for your help, I'll check this out with our customer but it's exactly what I was looking for.
Have a nice Day/Evening !
