OIDs for PVOS and OS-CX Health status
MVP
MVP
Q:
OIDS for PVOS and Aruba OS-CX switch Health Status
A:
OIDs for health status of aruba PVOS and OS-CX switch:
For Aruba OS (PVOS) switches,
CPU: 1.3.6.1.4.1.11.2.14.11.5.1.9.6.1
Total Memory: 1.3.6.1.4.1.11.2.14.11.5.1.1.2.2.1.1.5
Free Memory: 1.3.6.1.4.1.11.2.14.11.5.1.1.2.2.1.1.6
Fan: 1.3.6.1.4.1.11.2.14.11.5.1.54.2.1.1.4
Power: 1.3.6.1.4.1.11.2.14.11.5.1.55.1.1.1.2
Temperature: 1.3.6.1.4.1.11.2.14.11.1.2.8.1
In OS-CX, below MIB objects are supported for health check,
  1. HOST-RESOURCES-MIB(.1.3.6.1.2.1.25)
  2. Entity Mib(1.3.6.1.2.1.47)
  3. ENTITY-STATE-MIB( 1.3.6.1.2.1.131)
  4. ENTITY-SENSOR-MIB(1.3.6.1.2.1.99)
Example:
CPU:
HOST-RESOURCES-MIB::hrDeviceDescr.196608 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1518 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196609 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1518 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196610 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1518 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196611 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1518 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196612 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1518 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196613 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1518 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196614 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1518 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196615 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1518 @ 2.20GHz
CPU Status:
HOST-RESOURCES-MIB::hrDeviceStatus.196608 = INTEGER: running(2)
HOST-RESOURCES-MIB::hrDeviceStatus.196609 = INTEGER: running(2)
HOST-RESOURCES-MIB::hrDeviceStatus.196610 = INTEGER: running(2)
HOST-RESOURCES-MIB::hrDeviceStatus.196611 = INTEGER: running(2)
HOST-RESOURCES-MIB::hrDeviceStatus.196612 = INTEGER: running(2)
HOST-RESOURCES-MIB::hrDeviceStatus.196613 = INTEGER: running(2)
HOST-RESOURCES-MIB::hrDeviceStatus.196614 = INTEGER: running(2)
HOST-RESOURCES-MIB::hrDeviceStatus.196615 = INTEGER: running(2)
Memory:
HOST-RESOURCES-MIB::hrMemorySize.0 = INTEGER: 15454024 KBytes
HOST-RESOURCES-MIB::hrStorageIndex.1 = INTEGER: 1
HOST-RESOURCES-MIB::hrStorageIndex.3 = INTEGER: 3
HOST-RESOURCES-MIB::hrStorageType.1 = OID: HOST-RESOURCES-TYPES::hrStorageRam
HOST-RESOURCES-MIB::hrStorageType.3 = OID: HOST-RESOURCES-TYPES::hrStorageVirtualMemory
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: Physical memory
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: Virtual memory
HOST-RESOURCES-MIB::hrStorageAllocationUnits.1 = INTEGER: 1024 Bytes
HOST-RESOURCES-MIB::hrStorageAllocationUnits.3 = INTEGER: 1024 Bytes
HOST-RESOURCES-MIB::hrStorageSize.1 = INTEGER: 15454024
HOST-RESOURCES-MIB::hrStorageSize.3 = INTEGER: 15454024
HOST-RESOURCES-MIB::hrStorageUsed.1 = INTEGER: 2821484
HOST-RESOURCES-MIB::hrStorageUsed.3 = INTEGER: 2821484
FAN:
Fans list:
ENTITY-MIB::entPhysicalDescr.15001 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15002 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15101 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15102 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15201 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15202 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15301 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15302 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15401 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15402 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15501 = STRING: Aruba 8325 Chassis Fan
ENTITY-MIB::entPhysicalDescr.15502 = STRING: Aruba 8325 Chassis Fan
Fan Status:
ENTITY-STATE-MIB::entStateOper.15101 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15102 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15201 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15202 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15301 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15302 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15401 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15402 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15501 = INTEGER: enabled(3)
ENTITY-STATE-MIB::entStateOper.15502 = INTEGER: enabled(3)
Power Supply:
ENTITY-MIB::entPhysicalDescr.13001 = STRING: Aruba 8325 400W AC Power Supply
ENTITY-MIB::entPhysicalDescr.13002 = STRING: Aruba 8325 400W AC Power Supply
ENTITY-STATE-MIB::entStateOper.13001 = INTEGER: disabled(2)
ENTITY-STATE-MIB::entStateOper.13002 = INTEGER: enabled(3)
Temperature and other sensors:
ENTITY-MIB::entPhysicalName.7001 = STRING: Temp Sensor
ENTITY-MIB::entPhysicalName.7101 = STRING: RPM sensor for fan LC1-1F
ENTITY-MIB::entPhysicalName.7102 = STRING: RPM sensor for fan LC1-1R
ENTITY-MIB::entPhysicalName.7201 = STRING: RPM sensor for fan LC1-2F
ENTITY-MIB::entPhysicalName.7202 = STRING: RPM sensor for fan LC1-2R
ENTITY-MIB::entPhysicalName.7301 = STRING: RPM sensor for fan LC1-3F
ENTITY-MIB::entPhysicalName.7302 = STRING: RPM sensor for fan LC1-3R
ENTITY-MIB::entPhysicalName.7401 = STRING: RPM sensor for fan LC1-4F
ENTITY-MIB::entPhysicalName.7402 = STRING: RPM sensor for fan LC1-4R
ENTITY-MIB::entPhysicalName.7501 = STRING: RPM sensor for fan LC1-5F
ENTITY-MIB::entPhysicalName.7502 = STRING: RPM sensor for fan LC1-5R
ENTITY-MIB::entPhysicalName.7601 = STRING: Power sensor for power supply 1/1
ENTITY-MIB::entPhysicalName.7602 = STRING: RPM sensor for fan LC1-6R
ENTITY-MIB::entPhysicalName.7701 = STRING: Power sensor for power supply 1/2
ENTITY-SENSOR-MIB::entPhySensorValue.7101 = INTEGER: 12400
ENTITY-SENSOR-MIB::entPhySensorValue.7102 = INTEGER: 11500
ENTITY-SENSOR-MIB::entPhySensorValue.7201 = INTEGER: 12300
ENTITY-SENSOR-MIB::entPhySensorValue.7202 = INTEGER: 11300
ENTITY-SENSOR-MIB::entPhySensorValue.7301 = INTEGER: 12500
ENTITY-SENSOR-MIB::entPhySensorValue.7302 = INTEGER: 11400
ENTITY-SENSOR-MIB::entPhySensorValue.7401 = INTEGER: 12400
ENTITY-SENSOR-MIB::entPhySensorValue.7402 = INTEGER: 11300
ENTITY-SENSOR-MIB::entPhySensorValue.7501 = INTEGER: 12600
ENTITY-SENSOR-MIB::entPhySensorValue.7502 = INTEGER: 11500
ENTITY-SENSOR-MIB::entPhySensorValue.7601 = INTEGER: 0
ENTITY-SENSOR-MIB::entPhySensorValue.7602 = INTEGER: 11400
ENTITY-SENSOR-MIB::entPhySensorValue.7701 = INTEGER: 0
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7101 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7102 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7201 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7202 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7301 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7302 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7401 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7402 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7501 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7502 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7601 = INTEGER: nonoperational(3)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7602 = INTEGER: ok(1)
ENTITY-SENSOR-MIB::entPhySensorOperStatus.7701 = INTEGER: ok(1)
Version history
Revision #:
1 of 1
Last update:
‎04-16-2020 02:30 PM
Updated by:
