Wired Intelligent Edge
OSPF summary address only to advertise
  • 1.  OSPF summary address only to advertise
    Posted Aug 18, 2019 01:54 PM
    I have some 8320 and 5400 switches peering to our WAN provider ... I want to start distributing OSPF over this.
    To keep the routing table as small as possible for these links over the WAN, how can I set a summary address on the relevant interface?
    So effectively all the other sites just get advertised a summary address in OSPF for each other site?
  • 2.  RE: OSPF summary address only to advertise
    MVP GURU
    Posted Aug 19, 2019 03:46 AM
    for 8320, do you have look area X range XXX command ?
    ArubaOS-CX-Switch(config-ospf-2)# area 0
    default-metric Configure cost for the default route used for a stub or NSSA area
    nssa Configure OSPF area as NSSA
    range Summarize routes matching address/mask on border routers only
    stub Configure OSPF area as stub
    virtual-link Configure a virtual link<cr>
  • 3.  RE: OSPF summary address only to advertise
    Posted Aug 19, 2019 01:06 PM
    Thanks - so the area command is where you set the range? So you essentially assign a summary address to each area you make?
  • 4.  RE: OSPF summary address only to advertise
    MVP GURU
    Posted Aug 20, 2019 10:57 AM
    Yes
