Are you trying to connect these four switches in a ring, or a chain? The former is recommended for reliability, but may not be practical if you're also using the SFP(+) ports as uplinks for the fabric.
In a chain topology, if members are connected in order:
- Member 1 is connected to member 2;
- Member 2 is connected to members 1 and 3;
- Member 3 is connected to members 2 and 4;
- Member 4 is connected to member 3
To complete the ring topology, add a link between members 1 and 4.
Importantly, connections between different members must be assigned to different VSF links — any ports connected to the same neighbor must be part of the same VSF link.
Based on the output you posted, it appears that member 1 has connections to both members 2 and 3; members 2 and 3 have no second VSF link; and member 4 appears entirely isolated. Here are my recommendations (this will require taking the stack out of service for reconfiguration and recabling):
First: remove port 2/49 from VSF link 1 on member 2, and add it to VSF link 2:
switch(config)# no vsf member 2 link 1 2/49
switch(config)# vsf member 2 link 2 2/49
Second: add port 3/50 to VSF link 2 on member 3:
switch(config)# vsf member 3 link 2 3/50
Third: Ensure cables are connected to ports as follows:
- 1/49 <==> 2/50
- 2/49 <==> 3/50
- 3/49 <==> 4/50
- 4/49 <==> 1/50
Once everything is connected properly and the VSF merge is complete, the stack should operate as expected.
